civil3d 2020-Fatal Error while changing the structure style
raja_periketi
raja_periketi
Encountered fatal error while changing the drainage structure style.
audited the drawing.fixed errors.
any help will be greatly appreciated.
"Unhandled Access Violation Writing 0xa8c9cbe0 Exception at A8C9CBE0h"
Neil.Aryan
@raja_periketi
Make sure you have installed the civil 3d updates available on your computer and also install this updates as well and give a try,
https://knowledge.autodesk.com/support/civil-3d/downloads/caas/downloads/content/autodesk-civil-3d-2...
i am not sure this will fix your issue.
And also copy the structure into new file and try to change the style if you still have a problem share the effected file so that can have a look and find some way's to achieve what you wish.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
lynn_zhang
Hello @raja_periketi ,
Just checking to see if your problem has been solved. Did the response from @Neil.Aryan help answer your question? If yes, please click on the "Accept as Solution" button in his reply, or let us know if you still need help. Thanks!
Lynn Zhang
