Hi! I have to create template with slope-changing priorities. How can i set the slope priority and at the same time i want the edge of the template to also change when the slope changes in height from the existing surface?
Solved by c_teymurxanov. Go to Solution.
Solved by ecfernandez. Go to Solution.
Hi @c_teymurxanov. Use CutOrFill Conditionals. With them, you can set as many options as you prefer to control the insertion of a given subassembly depending on the Cut or Fill height.
I let you here a link to the Autodesk Help so you can check it
Link: Cut or Fill Conditionals
Best regards!
Hi @c_teymurxanov, happy to help. Let me tell you, I didn't understand quite well what you mean by "template," and when you say you want it to change the edge.
If the case is that you want the shoulder to have different dimensions when the height changes, include the shoulder with the specific dimension for each case after the conditional. In this way, when the height falls into a given value, the conditional will insert both the shoulder and the slope of your preference.
Let me know if this is what you were looking for, or develop your idea a little more to give you better advice.
Kind regards!
