Civil 3D User Interface - Commands Names Missing
Matheus-Lima
Advisor Advisor
Matheus-Lima
Hello there! Simple question about the user interface, specifically in Analyze >>> Volumes and Materials Panel.
The commands names for Total and Materials volume tables are blank and the other commands of the panel are just with the icon. Why does this happen? It is the same for me in both Civil 3D 2022 and 2023.
I thought it was a user interface setting but the command names are there. I guess I'm missing a setting or something. Thanks in advance!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Matheus-Lima
I found out the problem. I hid some panels of the Analyze Tab and the name of the commands came back. My screen is not wide enough, simple as that. Solved. 😅
Matheus Lima
