Civil 3D Points numbering order
Hi, i would like to know how can i change the direction which the points are placed via automatic insertion
In the picture it increases the numbers to the left side, i would like to change that direction.
andrewpuller3811
If that is a polyline, pick the other end of the polyline after starting the command.
The command starts the numbering from the end that of the object closest to where you pick it.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
JRitner
Hi @Anonymous ,
If you're creating points at polyline vertices automatically (Points > Create Points - Miscellaneous > Polyline Vertices - Automatic), you'll need to reverse the direction of the polyline first using PEDIT > Reverse, as points created using this method are based on the direction of the selected polyline.
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
Thanks @JRitner  and @andrewpuller3811  for replying, for my case i used the pedit command and it worked!
