Civil 3D geotechnical module
olubunmi.oluwole
Message 1 of 10
olubunmi.oluwole
Is Civil 3D geotechnical module contained in version 2021 or 2022?
Accepted solutions (3)
Replies (9)
Message 2 of 10
Udo_Huebner
Yes,
But you have to download and install it separately.
Gruß Udo Hübner (CAD-Huebner)
Message 3 of 10
olubunmi.oluwole
Thanks. Where can I get the module to  download?
Message 4 of 10
Udo_Huebner
You’ll find the geotechnical module for Civil 3D 2021 in your account https://manage.autodesk.com
The module is preconfigured to use it with Civil 3D 2022 as well.
Message 5 of 10
olubunmi.oluwole
Thanks once again. In my autodesk account, these are the Civil 3D related items I see in the AEC collection;
Civil 3D, Civil 3D - Grading Optimization and Civil 3D - Project Explorer.
Where is the Geotechnical module?
Message 6 of 10
Udo_Huebner
I can find it in Product updates:
Message 7 of 10
olubunmi.oluwole
Does anyone know if C3D_20ExtGeotechnicalModule.exe works with AutoCAD Civil 3D 2022?
Message 8 of 10
Udo_Huebner
Yes, it definitely works.
But you have to modify (SeriesMax="24.1")
C:\Program Files\Autodesk\ApplicationPlugins\AutodeskGeotechnicalModule2020.bundle\PackageContents.xml
to get automatically loaded with 2022
Message 9 of 10
tendría algún video de como instalar el modulo geotecnical, ya que se ve en la imagen que si le da, pero seria con un video mas explicativo por favor, se lo agradecería mucho. gracias de antemano
Message 10 of 10
Udo_Huebner
You are asking about the Geotechnical Module for Civil 3D 2022.
It's still not officially out yet.
Check also this thread: https://forums.autodesk.com/t5/civil-3d-forum/geotechnical-module-for-autodesk-civil-3d-2021-and-on-...
But with 2-3 simple steps you can get it working with Civil 3D 2022 with the following hack.
1. If both Civil 3D 2021 and 2022 are installed, simply install Autodesk Geotechnical Module 2020-2021
2. Then modify C:\Program Files\Autodesk\ApplicationPlugins\AutodeskGeotechnicalModule2020.bundle\PackageContents.xml
as described above
If only Civil 3D 2022 is installed, the current installer will not work because it only checks for the presence of a Civil 3D 2021 installation. You will then need to install Civil 3D 2021 or set a registry entry to fake an existing Civil 3D 2021 installation.
What Steps do not work for you?
