Civil 3D Curve Box
Civil 3D Curve Box
jntn
Civil 3D Curve Box
jntn
Can anyone help me making a label with details similar to the attachment?
When I use the Curve Label, I'm unable to get values for the spiral, and vice-versa.
Thanks in advance 🙂
Jeew-m
You can get a similar xml table from Alignment Curve report. Then you can get a excel table and import it to Auto CAD.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
jntn
Thanks for the info @Jeew-m but the chalange is I want a dynamic lable attached to the alignment.
You can create dynamic spiral labels and put them into a table pretty easily. The question is whether the out of the box SCS label components are enough. Or if it does not appear in the list below, can you use those components that *are* in the list in an expression to compute the data you want?
Check out Settings>Alignment>Label  Styles>Spiral and get into the Label Style Composer, Text Content Editor, and Settings>Alignment>Label  Styles>Spiral>Expression.
jntn
Hello @Anonymous ,
Thanks for your time,
actually the table is not the issue, it's just the information like spiral length and superelevation which is missing here.
Can you calculate that data from the curve/spiral components available to use in labels? It might help if you explained what the terms are in your application, Dc, Lc, Ts, Es, Ls, S(m), Ts (deg), D(deg), e(%).
