Civil 3D Creating elevation points on an existing 2D files
Message 1 of 16
I am very new to civil cad 3d and I have an autocad 2D file floor plan that I am working on.
I need to assign elevation/grade on the existing plan to find elevation points not given on the drawing.
I have been playing around with points etc and nothing is working.
Please help!
Replies (15)
Message 2 of 16
Joe-Bouza
...2d file floor plan.
Civil3d is a civil site infrastructure application. When you say floor plan it brings to mind architects and drawing units in inches.
Firs off units have to be dec feet or meters
Now what exactly are you trying to accomplish? Determine an FFE? There are way too many methods to take a stab at
Try to be a little more specific in what you want to do
Joe Bouza
Message 3 of 16
Yes I need FFE and the units are in meters.
So what I need are elevations at certain points on a given line. The original drawing is not drawn on a building pad or topographic surface. It is all flat. I want to assign elevations to it.
Hopefully that makes better sense?
Message 4 of 16
Ranjit_Singh
Not yet. It is not clear what you are trying to accomplish. Post the drawing. If possible do a screencast and explain a bit more.
Message 5 of 16
Message 6 of 16
Joe-Bouza
Ok
you can do this easily with your existing line work and >>>Create Feature line from Object.
start with the boundary of your slab and assign the top of slab elevation
then convert your rays going from the slab to the low points.
what you do not distinguish are the high points... These again and be computed using feature line to the location from the low point and setting the grade.
as you go aroung the floor you may find the need to add more detail.
either way: in the tool space prospector right click the surface collection an create a surface (name it or accept the default "surface1"... FG_Slab seem appropriate to me.
This creates an empty surface if you expand it there are choices of data>>> select all your feature lines>>> right click >>> add to surface as break lines.
Now you can Identify elevations anywhere on the slab.
This is one technique. There are myriad ways to accomplish this. IMHO this method is a good entry level method
Good luck
Joe Bouza
Message 7 of 16
I am not clear on the instructions yet.
Would it be possible for you to record yourself doing it if i send you the file? It would help majorly.
Please and thank you!
Message 8 of 16
The reason im asking to record is so I can use the technique on all floors.
Message 9 of 16
Joe-Bouza
Sorry I do not have c3d available to me at this time.
Let's discuss the instructions and maybe we can get past your road block
Joe Bouza
Message 10 of 16
Alright do I select one line on the boundary or should I make a polyline highlighting the entire boundary (TOS) of the plan?
I assigned the elevation in the dialogue box that pops up by creating a feature line, is that right? How do I create rays?
Message 11 of 16
Message 12 of 16
The steps I followed:
1) Select slab boundary lines and create feature lines (typed in 95.9 or 0.0959m as elevation in the dialogue box that pops up).
2) Typed the command "rays" and selected higher points direction towards low
3) Created surface
4) Selected all feature lines and added to surface as break lines
How do I select points to find elevation at a given point? I have not come across any prompted messages asking for my grade.
Thank you.
Message 13 of 16
user181
Hi @Anonymous. I created a quick screencast (no sound) showing how to create a surface using just feature lines. At the start I already made the boundary (TOS) breakline. There was already a surface I created so I just deleted the breaklines and added the ones I created. Then I used surface label to show elevations. Hope this helps.
Message 14 of 16
user181
I also turned off a few layers in the screencast to make it easier to see.
Message 15 of 16
THANK YOU THIS HELPED! and to everyone else for answering. Lets hope my boss is impressed ;D I appreciate it.
Message 16 of 16
user181
You're  welcome. If you have any trouble with it just ask.
