Civil 3D Better Way of Creating Reports in Layout Using ViewPorts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I am using Civil-3D 2016 version and I have already created a title-block in layout and want to print my work into a .pdf file. After placing the title-block into layout, I am creating multiple viewports in the layout for viewing different objects from the workspace.
The problem starts off in the viewports; in order to be able to see objects I do a ton of trial "regen" s to be able to see objects because they are all stacked up. Till this point it is still good despite the hassle of "regen" ing many times for a proper view!?!?!
Then when I switch between layouts, viewports and workspace, and as I try to bring objects into another viewport, the objects in the very first viewport, which I already organized everything finely, gets messed up... This gets really frustrating at times.
Is there a better way of creating multiple viewports in the layout and printing them into a .pdf file? I really appreciate if you can give a detailed description.
