Hello all,
I am using Civil-3D 2016 version and I have already created a title-block in layout and want to print my work into a .pdf file. After placing the title-block into layout, I am creating multiple viewports in the layout for viewing different objects from the workspace.
The problem starts off in the viewports; in order to be able to see objects I do a ton of trial "regen" s to be able to see objects because they are all stacked up. Till this point it is still good despite the hassle of "regen" ing many times for a proper view!?!?!
Then when I switch between layouts, viewports and workspace, and as I try to bring objects into another viewport, the objects in the very first viewport, which I already organized everything finely, gets messed up... This gets really frustrating at times.
Is there a better way of creating multiple viewports in the layout and printing them into a .pdf file? I really appreciate if you can give a detailed description.
Are you changing the scale of the viewports as this will also cause problems as you describe?
Can you post a dwg?
Thank you for your reply Jeff.
It still does mess up. I create a VP for example and "display locked" -> YES
made sure -> uscfollow -> "0"
I zoom in an regen for a table, then lock it and "copy" it in the same layout. Some times as soon as I copy it messes up both VPs and I need to go in regen again, but as soon as I modify one VP, move to next one for regen, then the first one gets messed up again. This is really nerve-wracking...
Any other suggestions?
Hi Neily,
I am not playing with the scale at all.
Please see the attached .dwg
layout-1-2-3 should be nice, and see layout4, which gives me trouble when I go between VPs.
Make sure ucsfollow is set to 0 in each viewport, though it shouldn't really matter if you are locking the viewports.
PS: Don't have time to look at your drawing right now.
Yes I do that for each VP but no success on getting it work consistent. Once you do, please see layout-4 in the file I sent earlier.
Hi Jeff,
But when I tried to get the scale to 1:40 this view is not as want and I zoom into the objects I want to view -masshaul diagram- then it automatically changes the scale as I see at the bottom. Shouldn't I zoom in? How do I get the view that I want then?
Freezing tables when getting other objects is a good idea.
