I just installed Civil 3D and Project Explorer.
I have a license.
Project Explorer is not working.
Why? What can I do about it?
Restart did not work.
Thanks.
Solved by Bruce-Harfield. Go to Solution.
Not much help but it installed for me with no issues
neilyj (No connection with Autodesk other than using the products in the real world)
try entering PROJECTEXPLORER on the command line. You have to add the license info for this as I think that it is considered an add-in, so needs its own licensing info. I also thought it was supposed to go on the Add-ins ribbon tab, but I am not seeing it on mine after providing a license. I may be and probably are wrong about where the button is, but PROJECTEXPLORER works.
I'm still trying to figure out what good this thing is?
