Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3d 2021 to Civil 3D 2022 Issues With Pipes and Errors
gpserra
gpserra
I've decided to upgrade to 2022 again after trying it last year and having a terrible time. In general I like to stay a few months behind so that all the bugs get ironed out.
This time around everything seemed to go smoothly the first day, but now I'm getting SHX file missing for fonts (which I don't get when opening with 2021), and more crucially my pipe editor won't show me the part lists of each network. I can see all the part lists in Toolspace, but not on the editor (See Pictures).
Is there something I'm doing wrong? I was thinking maybe I need to update, but it seems like I'm up to date.
Elina.P
Autodesk Support
Autodesk Support
Hi @gpserra! Thank you for your question.
Regarding the SHX file missing, try one of the solutions suggestions from the following article:
"One or more SHX files are missing. What would you like to do?"
Regarding the second issue, try the following suggestions:
  • Make sure the Pipe network catalogue is set to the correct location.
  • Use _PARTCATALOGREGEN command to regenerate the pipes and structures.
Hope this information will help you!
Elina P.
Technical Support Specialist
Civil Engineering Solutions
gpserra
I got The SHX issue fixed. Thanks for the help!
As far as the parts missing not so lucky. The location of the Part List is in the Correct spot as far as I can tell (See attached), and it's showing in use for the current pipes and structures already in the drawing. It just wont let me add more, so I have to go to 2021 to add more structures.
Elina.P
Autodesk Support
Autodesk Support
Hi again @gpserra !
Thank you for confirmation! For the second issue, try one of the solutions proposed in the below article:
Pipes and structures do not appear during pipe network creation but show up in the Toolspace in Civi...
Let me know whether it helps you or not!
Elina P.
