Civil 3D 2020.1.1 (13.2.1404.0) Issue Display Points Surface
Hello everyone,
Normally to edit a surface I turn on the points of the vertices through the style. I updated Civil 3D to version 2020.1.1 (13.2.1404.0) and now when I turn on the surface points the points appear along with a label with the elevation, which I cannot change and slows down the software operation.
Figure 1. Surface points on. Civil 3D 2020.1 (13.2.1378.0)
Figure 2. Surface points on. Civil 3D 2020.1.1 (13.2.1404.0)
I appreciate if someone can help me.
Mauro Vega
AllenJessup
You don't happen to have the DACH extension installed do you?
Allen Jessup
CAD Manager - Designer
Hello @AllenJessup
Yes, I have the extension installed. Is the problem associated with this extension?
Could you help me?
Thanks.
Mauro Vega
AllenJessup
If you have the extension installed on a non-German product. There's an answer here:
https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Error...
I got that from here: https://forums.autodesk.com/t5/civil-3d-forum/surface-style-displaying-points-with-elevation-label/m...
But the link in the post is broken.
Allen Jessup
@AllenJessup
Thank you so much!
Regards.
Mauro Vega
AllenJessup
@Anonymous  Glad to help.
Allen Jessup
