Civil 3D 2019.2 Update - Right Click Menu?
fcernst
Mentor Mentor
Message 1 of 8
fcernst
I am not getting Transparent commands when I right-click while editing a Profile... It just cancels the command.
What am I missing?
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Replies (7)
Message 2 of 8
Mike_Hurtado
Autodesk Support
Autodesk Support
Hey @fcernst,
I tested this and confirmed the same behavior as far back as 2016. After double checking with development, they confirmed that both the alignment and profile layout tools have used right-click to end a command for a long, long time.
Michael Hurtado
Designated Support Specialist
Message 3 of 8
fcernst
The Update says the Transparent Commands are now accessible using right-click:
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 4 of 8
Mike_Hurtado
Autodesk Support
Autodesk Support
That unfortunately doesn't apply to all commands. I'll look into making a change to the read-me to avoid confusion.
Thanks for bringing it to our attention.
Michael Hurtado
Message 5 of 8
fcernst
...That unfortunately doesn't apply to all commands. I'll look into making a change to the read-me to avoid confusion.
Thanks Mike, but can you tell us here now what commands the Transparent Command right-click functionality does apply to?
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 6 of 8
BrianHailey
Fred,
Not sure if this is an option for you or not but if you turn on the time-sensitive right-click option, it works.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 8
fcernst
Hey thanks Brian..that does work!
I did not even know that setting existed...
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 8 of 8
BrianHailey
When I was doing design back in LDT, I always had that turned on. Nowadays, since I'm constantly teaching on systems that are default, out of the box installed, I leave it turned off because it's different than what I'll see in my classes. It's the same reason I don't install any lisp routines on my system. I don't want to get into class, and expect to do something one way and not have access to it or, do something my students won't be able to do on their systems.
GEI Consultants
My Civil 3D Blog
