Civil 3D Forum
Civil 3D 2017 is not backward compatable.
162 REPLIES 162
Message 1 of 163
ChrisRS
22363 Views, 162 Replies
I suspect that this is the cost of progress, so it OK. Just be aware.
When 2016 was backward compatible with 2015, AutoDesk clearly said so. It would be nice if they spoke as clearly now.
From the help File:
Interoperability Between Versions
This topic describes the behavior when an AutoCAD Civil 3D 2017 drawing is opened in prior versions of AutoCAD Civil 3D.
Objects in a drawing saved in AutoCAD Civil 3D 2017 are available only as proxies when the drawing is opened in a prior version of the software.
Within AutoCAD Civil 3D 2017, set the PROXYGRAPHICS drawing setting to 1 to save the graphics with the drawing, otherwise a bounding box is displayed where the object is located when the drawing is opened in a prior version of the software.
Notice whenyou open an older version file:
Christopher Stevens
162 REPLIES 162
Message 2 of 163
neilyj666
in reply to: ChrisRS
My understanding is that the Vanilla ACAD dwg format remains the same for 2017 but as you have discovered the Civil 3D dwg has been upgraded so incompatibily issues will abound.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 163
scaldwell73
in reply to: neilyj666
That probably kills my idea of snagging the 2017 pressure pipe catalog to use in 2016 then. We just made the move to 2016, don't see us moving again for a bit.
Shawn Caldwell
Gay & Neel, Inc.
Message 4 of 163
ChrisRS
in reply to: scaldwell73
Shawn,
"That probably kills my idea of snagging the 2017 pressure pipe catalog to use in 2016 then."
I don't know if the 2017 catalogs can be used in 2016. Let me know if you try them. The 2017 Help file referes to the new catalogs but not mention if there has been any change that would prevent them from being used with 2016.
You might want to look a Project Kameleon in Atuodesk Labs. I recently added the ability to work with pressure pipe content. (I have downloaded and looked at but not worked with it.)
Christopher Stevens
Message 5 of 163
Cadguru42
@ChrisRS wrote:
Shawn,
I thought Kameleon was dead. I tried it out and asked for help and no one on the forums nor from Autodesk ever responded so I gave up. Their own tutorials wouldn't work due to changes to the software and no one from Autodesk would assist.
C3D 2022-2025
Windows 11
32GB RAM
Message 6 of 163
dsimeone
in reply to: Cadguru42
Few topics i'll try to respond to...
  1. Civil 3D Object Format - Yes, we made the hard decision to update our objects for Release 2017. This enabled us to properly implement the improvements in the initial release AND also provide us a platform for some things that we're hoping to deliver during the year.
  2. Pressure content - We intend on delivering the pressure content as a unique doanload for R2016 subscribers. Still working out the logistics but it'll be raw content that you import into Civil 3D 2016
  3. We're still actively developing Kameleon. The long term vision is that this becomes a general content creation environment... For C3D users, i see it as the future solution for creation of both gravity and pressure content. For now, Kameleon will remain on Labs so please continue to stay involved with that project.
Dave Simeone
Senior Product Manager - AutoCAD Civil 3D
Dave.Simeone
Product Line Manager, Autodesk Infrastructure Products
Message 7 of 163
scaldwell73
in reply to: dsimeone
Thanks for the update, Dave. It's appreciated.
Shawn Caldwell
Gay & Neel, Inc.
Message 8 of 163
ChrisRS
Thanks for the update. It is great to see Autodesk responding.
Christopher Stevens
Message 9 of 163
jporter
@dsimeone, does this mean the EXPORTTOAUTOCAD drawding that is created will not be compatible with earlier versions as well.  This is what i'm seeing:
https://knowledge.autodesk.com/community/screencast/7bac8fc2-3859-4214-a874-1a36f872298c
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 10 of 163
rl_jackson
in reply to: jporter
I would say the drawing will be compatible
None of the C3DObjects will work - (ie Points, Styles and Other objects)
Rick Jackson
Survey CAD Technician VI
Message 11 of 163
jporter
in reply to: rl_jackson
@rl_jackson, that's what you would think.  But take a look at the video link that I provided and you'll see that it does not work.  I've tried it on several computers and several users.
Jason Porter
www.asti.com
Message 12 of 163
rl_jackson
I had looked at the video, all the proxy objects are all your C3D objects and they will not work once the drawing is saved in C3D17. You'll need to xml out those object or revert to a previous version not open in 17. All dumb acad line work should be valid. (Export will not convert objects for use in earlier versions hence the proxy warning)
Rick Jackson
Message 13 of 163
jporter
Yes, but the export should have converted those proxy objects down.  Am I correct?  It's always worked that way in the past.
Jason Porter
www.asti.com
Message 14 of 163
rl_jackson
It has only worked from 13 through 16. Prior to that no release was compatible with any other release of C3D period.
The export command has never converted C3D Objects to earlier version for that version to use. You will need to recreate your drawing via XML (blocks) or other means, in the version 13-16.
Rick Jackson
Message 15 of 163
rkmcswain
Agreed. C3D 2017 > 2016
--is just like---
C3D 2012 > 2011 (or 2013>2012, or 2011>2010, etc)
Correct?
Message 16 of 163
jporter
in reply to: rkmcswain
I'm not looking for it to convert Civil 3D objects to earlier versions. I'm simply looking for it to convert the entire drawing to AutoCAD linework with no proxy objects.  I want that alignment to convert to a polyline with text labels, I want the surface to convert to bunch of polylines with elevations, etc., etc.
Jason Porter
www.asti.com
Message 17 of 163
jporter
I believe the best solution may be to. . .
  1. In 2017, export to AutoCAD and export to Land XML
  2. In 2016, open the AutoCAD drawing and delete all the proxy object boxes.
  3. Import the Land XML file.
Jason Porter
www.asti.com
Message 18 of 163
rkmcswain
I would agree with that, and if proxyobjects = 1 in v2017, then there won't be any proxy boxes to get rid of.
And if your final desired result really is a polyline and text, you don't need to import the landxml file.
Message 19 of 163
JamesMaeding
Just saw this thread.
If the ability to saveas to lower versions without exploding the aec objects caused problems, this "autocad is same version but c3d objects are not" is going to be *fun*.
The question at hand is:
If we EXPORTTOAUTOCAD, and tell the aec objects to explode, do they?
We do not care about converting c3d data back, that went out the window long ago.
The answer MUST be that , yes, the objects explode.
Just be sure to tell the batch converter or export commands to do so.
Be sure to turn off the bind in options as well as in the civil batch converter dialog, they both must be off or you get in a bind...pun semi-intended.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 20 of 163
jporter
@rkmcswain, at this point yes the final desire was to get it to Vanilla AutoCAD format.  This was to get to a client who doesn't have Civil 3D, but only AutoCAD.
I went back through my process and I clarified it.  Here's what you need to do to get it out to AutoCAD and Civil 3D:
  1. In 2017, export the file to AutoCAD and Land XML
  2. In 2016, begin a new drawing
  3. Assign it the same coordinate system as the original drawing
  4. Insert the AutoCAD file (you’ll see you’ve lost all proxy objects)
  5. Insert the LandXML file
Now if you need to get it back to AutoCAD format for someone else to use. . .because of the fact that you lost those proxy objects in step 4, you'll need to proceed to the end of step 5 and then you'll need to have it open in the earlier version of Civil 3D and then export the file to AutoCAD.
Jason Porter
www.asti.com
Rail Community
