Civil 3d 2016 - RUN SETUP.EXE TO INSTALL AUTOCAD 2016
mikeshick
mikeshick
I get the statement above every time I ope a program called CFS (cold form steel).  I also have Architecture 2016 installed, and tried a reinstall on this, but no betta.
Any ideas what is causing this?
Mike Shick
www.medesigns.us
Replies (10)
Civil3DReminders_com
You'd have to contact the creator of CFS or install basic AutoCAD. It probably is looking for a registry entry that is created when AutoCAD is installed. Civil 3D gets installed in the registry in the same location, but has a different folder.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
mikeshick
The problem only started after I loaded C3D 2016 and Arch 2016 on one machine.  When I loaded on a second machine, it didn't have any problems with CFS.  I've had CFS loaded for years without that requirement.  Any other ideas?
Mike Shick
www.medesigns.us
Deion.Wanchope
Hi mikeshick,
My name is Deion and I will be helping you with your request.
I understand that in you are receiving a "RUN SETUP.EXE TO INSTALL AUTOCAD 2016" error, but I will be more than happy to help you with this issue.
Here is a link to an article with a few steps that will guide you to a possible solution for this problem: Click here
Please let me know if the information provided solved the issue and feel free to ask if you have any additional questions or concerns regarding this Support Request.
Deion Wanchope
mikeshick
Oh...that's kind of horrible.  Must it require an uninstall....after a few hours of setup 😞
Mike Shick
www.medesigns.us
Deion.Wanchope
Hi mikeshick,
I do understand your frustration. At this time the only fix that we have available is to perform a clean uninstall/reinstall. Our development team is currently looking to see if a fix can be provided in a future release or update.
Best regards
Deion Wanchope
mikeshick
Thanks, Deion. Too frustrating!
Mike Shick
www.medesigns.us
dilsmails
Hi I am getting this error (image attached) during re install after un install the program, any help please ……
Dileep
I'm getting the same message "Run Setup.exe to install AutoCAD 2016" every time I start Microsoft Word!!!!!!!
I started getting the message after I uninstalled AutoCAD 2013.
cleipold
I have today the same failure with AutoCAD Civil 3D 2018. And I repair Civil 3D and the Problem was solved. I think it is a better alternative.
Best wishes
After I have done a repair for Autocad 2018, my simulation programs worked.
