Civil 3D Forum
Civil 3d 2016 default pipe flow direction
3 REPLIES 3
lambertb
939 Views, 3 Replies
Is there a way in civil 3d 2016 to make the default pipe flow direction By Slope? It seems defaulted to Start to End.
C3D 2022 and 2024
3 REPLIES 3
BrianHailey
in reply to: lambertb
Not that I'm aware of.
If you post this up in the idea station, let me know, I'll definitely vote it up!
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
lambertb
in reply to: BrianHailey
Here you go.
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/pipe-flow-set-default-to-set-default-to-by-slo...
I did see forum posts starting back in 2008 on the pipe flow direction topic.
C3D 2022 and 2024
kehale
Flow Direction and Storm Sewers add-on.  It is necessary to set the flow direction to 'By Slope' before exporting to Storm Sewers.  If any of the pipes has an incorrect flow direction, Storm Sewers will show the downstream pipe as an outfall. As was posted before, right click on the Flow Direction header in the panorama and select "By Slope", then export.  And Kudos to the person who originally posted the fix cited above.
Rail Community
