if you do have a stable system, hold it in that state. I don't see advantages to update to Windows 10.
And if you want to use Windows 10, then do not update, but run a fresh install on a formatted harddisk and make sure to have new drivers for your hardware (which are built for Windows 10). By any chance test first (on a test system) that your plotter runs with Windows 10, most messages I see is that plotting has issues with older plotters.
I do not see troubles with C3D 2016 or 2017 with Windows 10 (which would not have occured in older Windows releases too).
I'm also having C3D 2015 installed and it works, but that is only for testing, not the daily work so I can't say if it is more or less stable in Windows 10.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
