Civil 3D Forum
Changing Annotation Scales Does Not Resize COGO Points and Labels
27 REPLIES 27
Message 1 of 28
dkoss44JHU
5665 Views, 27 Replies
Hi All,
This has been happening on and off to me for a while and I have no idea what to do.
As the title says, I change the annotation scale and COGO points and labels do not change size.
  • Some days it works, some days it doesn't.
  • Sometimes exiting and restarting the program fixes it, more often it doesn't. Same with restarting the computer.
  • Annotative dimensions and leaders DO change size when the annotation scale changes, even when COGO points and labels do not change.
  • This happened in Civil3D 2021, an upgrade to 2022 did not help.
  • If I change the annotation scale and then rotate a point or move a line with a label on it, that specific point or label changes scales and a regen then changes the sizes of all objects.
  • If I go to Toolspace, Settings, right click on the drawing, Edit Drawing Settings, and change the scale in the Units and Zone tab that DOES change the size of all objects, every time.
  • This happens in all drawings. Ones from other companies sent to us, ones started from our template, ones started from the default template, etc.
Any ideas on what I can do to fix this? It's a real pain.
Dan
27 REPLIES 27
Message 21 of 28
allanviictor
in reply to: dkoss44JHU
Botão direito no gopo de pontos e vá em propriedades, depois editar point label style como na imagem.
Na aba Layout você pode editar o tamanho da fonte ou outros aspectos.
Message 22 of 28
pohjarakennus
So I found a solution that worked for a similar issue that I had:
-First add the cogo points to a point group and then assign the group a style.
-In the point style settings (right-click -> properties) there is a tab named 'marker'.
-In the top-right hand corner there is a size option that allows you to change the points based on drawing scale.
Hope this helps!
Tags (3)
Message 23 of 28
edbusanaPUFJB
Check this solution
Point style: In point group property - point style - Marker tab - use size as "fixed scale" or "absolute units".
Point Label Style: For Layout tab modify the scale in Toolspace - Edit Drawing Settings. For Model tab modify the scale in the bottom bar of the window.
Message 24 of 28
ethanE3D65
I have just started experiencing the same thing in my 2022 version of Civil 3D. As others stated, using the drawing settings in tool space works, but not the annotation window in the status pane. Have been working with Civil 3D for over 10 years and haven't experienced this one before
Message 25 of 28
lgentileZY46F
in reply to: ethanE3D65
I've found that if I click specifically on a COGO point, and use the regen command, it resizes the points!
Message 26 of 28
ethanE3D65
in reply to: lgentileZY46F
that is definitely working and how I am proceeding. Like others have stated, just a little bit more of a PITA. I just recently had to use a 20 year old version of microstation to satisfy a DOT project though and will take these minor Civil 3D work arounds over that any day!!!!!
Message 27 of 28
ynnad_ogana
regen enter then click any labels then enter again or may click any label 1st then regen enter
boom..
Message 28 of 28
Cadguru42
https://forums.autodesk.com/t5/civil-3d-forum/2017-cogo-point-labels-not-updating-to-drawing-scale/m...
This has been a bug for 9 versions that's never been fixed. I still don't know what causes it nor how to fix it. Neither does Autodesk, apparently.
C3D 2022-2025
Windows 11
32GB RAM
Rail Community
