Change the Alignment Station Label Style
I'm trying to create a label style that shows the stations like (1-20, 2-40, 3-60). Basically the number of the station and the total lenght of it. Someone already make something like this? I tried to change the contents on label style composer but not worked.
Sorry for the bad english, i'm from Brazil. Hope that you could understand my doubt.
Thank you!
SMorykin
@Anonymous - I think I have half of what you're looking for (See screenshot attached) by using expressions in the Alignment label styles.  I just wanted to clarify - is the 1, 2, 3 just a counter you are using or does it represent a specific point on the alignment?
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
erdemcelenk
Hey,
I think I would create cogo points throughout the alignment by measuring it (using any interval you'd like to have) .Those points would have numbers automatically (0,1,2,3 etc. ) and I 'd show those numbers by assigning a Point Label Style onto the points and using an Aligment Station Label Group in a decimal form (since it'd display the length then) could work. See the attached image.
I hope that is what you wish to do.
Erdem Çelenk
Civil Engineer,MSc.
Jowennl
Hi @Anonymous,
Here's a detailed guide. I created an expression for 20 Interval and use it in my alignment label and it works.
Guide Image 1Guide Image 1Guide Image 2Guide Image 2Guide Image 3Guide Image 3Guide Image 4Guide Image 4Guide Image 5Guide Image 5Guide Image 6Guide Image 6Guide Image 7Guide Image 7Guide Image 8Guide Image 8Guide Image 9Guide Image 9Guide Image 10Guide Image 10
Good luck.
Cheers,
Jowenn
