Hello everyone!
I've been struggling with this problem since I started to work with pipe networks.
Often, I have to assign pipes and structures, different reference surfaces and alignments. However, when I select a group of them, I can't select, for example, a reference surface for all of them, because the "pipe properties" or "structure properties" button, because that button can only work with one structure or pipe at time.
Is there a way to change the reference surface or alignment for a group of structures or pipes at the same time?
Certainly, I can enter in the Pipe Network Vistas and change the properties of multiple parts. But in that space, I can't select pipes from the model space. Instead, I have to select them from the Pipe Network Vistas, forcing me to "guess" what parts I have to select.
I would appreciate your help with this issue.
