Change MH part connection to pipe invert elevation
jwilk1414
jwilk1414
Good day, I have a Headwall here that is not connected to the pipe invert properly, how would I change this? Part Builder? The invert needs to be on the top of the flat part, currently its about a 1/3 up the pipe so I need to move the pipe upwards.part connection.png
tcorey
I can't give you a definitive answer without a drawing but look in structure properties for surface rim adjustment.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
lim.wendy
Hi Jessi,
Thanks for posting.
Tim suggested adjusting the surface rim in the structure properties as a potential solution to the issue with the Headwall not connecting properly to the pipe invert. Have you had a chance to explore this suggestion? If not, could you please share the drawing?
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
