change color of contour lines by elevation
ivaan0110
ivaan0110
Hi
I was wondering if it is possible to change the color of the contours depending on the height of it but without having to explode the surface
in the attached file would be the result but with the surface exploded
SMorykin
@ivaan0110
Hi!  You could use the "Surface Properties > Analysis" tab of the surface to get your color scheme.  Change the analysis type to "Contours", enter in your number of ranges (hit the down arrow) and view your min./max elevation ranges.
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
MMcCall402
Yes it can be accomplished with a combination of Surface Property settings and Surface Style settings.
In the surface properties you'll need to set up an Analysis for contours with contour ranges.
In the surface style you'll need to set the Contour Ranges to use the Color Scheme, set the schemes to Rainbow, and then on the display tab be sure to set the color properties of the contour layer to be BYBlock.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
ivaan0110
Hi
thanks for answering
My question is if it is possible to change the color of the lines by height
(as it is in the image)
do not create a block of colors
thanks
tcorey
That's what the previous posts are showing you, how to change the color of the contours by height. There is no other way with a surface.
If you extract the contours from the surface, you could apply a LISP routine to change the polyline colors based on elevation but, remember, AutoCAD has only index 256 colors.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
MMcCall402
Like this?  It divides the rainbow of colors across all of the contours in the surface.
or were you looking for each contour line to be a different color?
Mark Mccall
CAD Mangler
Linkedin
ivaan0110
Thanksssss¡¡
