Capturing a bing map image
I cant remember exactly but awhile ago Mike Carlson showed a trick how to save a bing capture shot with later versions of civil 3d 2016. It had something with using geolocation.
Does anyone know where that link went?
Alfred.NESWADBA
when you already have the areal image data visible from bing maps (using command _GEOMAP) you can then use command _GEOMAPIMAGE for a window or for a current viewport to "mount" this image into the dwg-file.
After that you can select + right-click the embedded image to change it's options:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Ar.Semikin
Is it possible to save this part of the map as an image?
