Announcements
Cannot select folder for Pressure Network Catalog
marcus.freemanWP78H
marcus.freemanWP78H
Hello all,
I have tried almost all of the ways that previous searches for this issue suggest.  I have not seen any posts about this still happening in C3D 2025, but it is...on some machines.
Entering SETPRESSURENETWORKCATALOG at command bar opens the window where you navigate to the folder that contains the libraries.  When i get to the Imperial folder, it tells me there are no catalogs in this folder.  I have edited the registry on these machines and it does not work.  I have two identical machines (as far as i can tell) and I can only set the catalog on one of the machines.  It makes no sense to me why this isn't working.
I had another machine where it wasn't working, but I tried it as you normally would again, and it did work.  Again, this makes no sense to me.
I really don't want to uninstall and reinstall.  Are there any current solutions that anyone can come up with later than 2018?
VincentSheehan
Have you tried to Reset Settings to Default?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
marcus.freemanWP78H
That is what I ended up doing to fix the issue.  Not that big of a deal, but I wanted to avoid it if possible.  It's still much better than a complete reinstall.
Type a product name
