Cannot project solid object to section view
I have five solid objects that I am trying to project.  Four of them appear but one does not.  All objects are set to the same layer, style, etc.  All of them are well within the field of view in about the same location and appear in object viewer and look fine in isometric.  However when I open section view properties and click on the projections tab there are only four objects listed.  Tried re-projecting the 5th object several times but still only four of them show up in section view properties.
I seem to have discovered a work-around.  If I go into section view properties and click on the small icon in the lower right corner labeled "Pick objects", then select the solid object, it successfully adds it to the section view.  The problem occurs when I try to use the drop-down menu on the ribbon Home>Profile & Section Views Panel>Section Views>Project Items to Section View.  Seems to be another bug in ver. 2019...
mehdi.Autodesk
I have the same problem this change solved my issue
1- Open Projection style
2- Go to profile Tab
3- Activate the Tick for section
 Also good Luck (:
lynn_zhang
Hi @mehdi.Autodesk
Glad to hear you fixed the issue and thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
Lynn Zhang
