cannot offset an alignment
cmy75025
cmy75025
Hi all,
I want offset an alignment('Offset' function, not 'offset alignment') but some alignment cannot offset an alignment
이미지 1.pngI tried to offset this alignment at various intervals, but all failed.
All other alignments have a successful offset function, but only this alignment does not work.
Why does this happen? And how do I solve it?
Jowennl
Hi @cmy75025 ,
If you want to use just offset command and it won't work, check the bearing if you need to remove an IP that have the same bearing for both tangent.
This happen because you got the same bearing. See attach guide images below and attached dwg.  If you want to label the profile at 80.09 then add it as station equation rather than IP.
Guide1Guide1Guide2Guide2Guide3Guide3
Cheers,
Jowenn
cmy75025
Your reply really helped me a lot.
Thank you for your help.
