Thanks, Here is my issue: this is all the help file says: External Climate File A user-prepared climate file where each line contains a recording station name, the year, month, day, maximum temperature, minimum temperature, and optionally, evaporation rate, and wind speed. If no data are available for any of these items on a given date, then an asterisk should be entered as its value. An example from a user-prepared climate file is shown below: Figure 10.3 Example user-prepared external climate file When a climate file has days with missing values, the software will use the value from the most recent previous day with a recorded value. For a user-prepared climate file, the data must be in the same units as the project being analyzed. For US units, temperature is in degrees F, evaporation is in inches/ day, and wind speed is in miles/hour. For SI metric units, temperature is in degrees C, evaporation is in mm/day, and wind speed is in km/hour. There is no instruction on how to prepare the TXT file input tab delimted? comma delimited? space delimited? ANSI? UTF-8? issues with the final line? The file that was sent was .dat but I am trying to use a .txt option does it need to be .dat? how to turn a .txt into a .dat?
Hyphae (pl. noun): The fine, weblike, branching tubes which make up the body (or mycelium) of a multicellular fungus, responsible for symbiotically sharing nutrients between soil and plants.
