Cannot load a custom north arrow
codyC2QXC
Message 1 of 8
codyC2QXC
I have made a custom north arrow. However the window for "load from this drawing" is blank despite there being hundreds of blocks defined in this drawing. If I click on the ellipses load from a file the "OK" button stays grey and will not let me load it. Thoughts?
Replies (7)
Message 2 of 8
MSchille-1994
I have not seen that dialog box before.  How are you trying to load this?  Designcenter?
Attitude, not Aptitude, Determines Altitude
Message 3 of 8
codyC2QXC
layout tools
Message 4 of 8
CodeDing
@codyC2QXC ,
It does not appear to be recognizing any from Current Drawing.
Export your North Arrow to its own DWG file somewhere.
(be sure you have the "Map.View.Rotation" parameter in it)
Then, use the ellipses (3 dots) to select that DWG file and it will show your North Arrow Block.
Best,
~DD
Message 5 of 8
codyC2QXC
From my original post.
"If I click on the ellipses load from a file the "OK" button stays grey and will not let me load it."
Message 6 of 8
RobertEVs
Try purging out any original blocks then insert the new arrow
Message 7 of 8
doni49
But did you also verify that your block definition includes the parameter specified above?  That's what tells Acad what angle to use for the rotation.  Any blocks that don't include this parameter will not show up in the dialog.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 8 of 8
tcorey
OK remains grey until you select a block from the list.
vs
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
