Hello Everyone,
I am having an issue with surface editing within C3D 2017. When I attempt to edit a surface by deleting a surface point or surface line, I am unable to remove those entities because the "selected entity must be part of the main entity." I have isolated this issue to a single machine, when I open the drawing on another machine I am able to edit the surface by deleting points and lines. To try an fix this issue I have done a clean uninstall and reinstall of C3D 2017 and have applied the current updates, and still have the same issue.
Has anyone seen this issue? Any ideas on a solution?
The quick solution is to use the other machine to edit the surfaces, but not a long term fix.
I have posted a Screencast of the issue that I am seeing, I have also attached the DWG as well.
Currently running:
- Product Version:
- 11.0.656.0 Autodesk AutoCAD Civil 3D 2017
- Build on:
- N.402.0.0 AutoCAD 2017.1.2 Update
- N200AC Autodesk AutoCAD Map 3D 2017.0.3 Hot Fix
- 7.9.48.0 AutoCAD Architecture 2017
Thank you for your help!
