Cannot Detach XRef drawing
tonykhoury
tonykhoury
I cant detach the drawing. Everything is greyed out.
Please see attach.
Thanks for your help.
Guillaume.Desmedt
Check Tree connection of XRef if your reference is in another one.
If isn't, try to change located path at the bottom of your screenshot. If you don't have this file, change by another one (blank e.g) and detach this file after.
Rgds
Guillaume DESMEDT | BIM Infra Guy
Joe-Bouza
If it was xref in ps on multiple lAyout tabs it will not give the detach option until the layouts are removed or xref deleted fro same
Joe Bouza
tonykhoury
Guillaume,
Check Tree connection of XRef if your reference is in another one.  Can you elaborate on this one ?
If isn't, try to change located path at the bottom of your screenshot. If you don't have this file, change by another one (blank e.g) and detach this file after. This one didnt not work ?
Tony
tonykhoury
Joe,
  1. The file is deleted for the folder.
  2. The drawng is referenced in model space and not in paper space.
Tony
Jay_B
Let's say for example you have drawing A which has drawing B attached as an Xref.
Then within drawing B, drawing C is attached as an Xref using "Attachment" Type.
This causes nesting and is considered a nested Xref in drawing A.
Now drawing C has been deleted, so file C.dwg is greyed out in the Xref Manager from file A.dwg and cannot be detached.
Try opening drawing B and detaching the missing xref there.
If that doesn't work, try as @Guillaume.Desmedt has suggested and simply repath the missing xref in drawing B to any other dwg.
Then detach the repathed dwg file.
First set to Tree View on upper right of Xref Manager
If you need to try repathing drawing C to another file from drawing B, browse to the file in "Saved Path" here:
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Joe-Bouza
got it
Joe Bouza
