Cancel Command/Deselect Object Makes Drawing Window Not Active
This is a new issue I am having after upgrading from 2015 to 2017. When I hit ESC or SHIFT to deselect a feature line or any Civil 3D object, it seems I must click or pan within the drawing window before trying to type a command or use the mouse wheel to zoom. Until you click within the drawing window or pan, the standard Windows cursor is present instead of the normal AutoCAD crosshairs & pickbox. It is like it takes you out of the drawing window. For example, if you don’t click into the drawing window before starting to type the next command, you start evoking the quick access keys, same as if you hit the ALT button, as shown below.
When hitting ESC after selecting normal objects like polylines, the normal AutoCAD crosshairs & pickbox are present and you can begin typing commands immediately as you always have. Is anyone else having this issue or know of potential solutions?
