Civil 3D Forum
Can We Edit Feature Line Reports???
4 REPLIES 4
734 Views, 4 Replies
i need to report eg surface detail coordinates and offset from cross section. So i use feature line report from reports manager... it gives what i want but not correct order. i want result not by row,by column... attachmnet pic. you can understant what i mean...  is it possible to change format of reports???
4 REPLIES 4
Civil3DReminders_com
All of the reports are customizable, so it is possible to change the output. You could export to Excel instead of HTML and modify the data there. There are also products out there that will provide an easier way to get the info. Such as ProjectExplorer http://3am-solutions.com/
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Hello. Does anyone know how to get 3 decimal places in a feature line report?
Would like 0.000 precision for both coordinate and elevation.
I've tried to make changes to some xsl files in this path ----->C:\ProgramData\Autodesk\C3D 2014\enu\Data\Reports\xsl
No luck. Any ideas?
Corey
Jeff_M
in reply to: c.smith43TSP
@c.smith43TSP, the Featureline Report is a .NET based report, not XSL. You could edit the source code to get it to use the correct Ambient settings for elevation and coordinate, or you can just set the Ambient setting that the lazy programmer decided to use instead. All of the output for the report are formatted using the Alignment Station precision, so edit that in the Drawing's AMbient settings and your report will look as you wish...unless, of course, you only want 2 decimal places for the stationing....
Jeff_M, also a frequent Swamper
c.smith43TSP
in reply to: Jeff_M
Bang on. Thank you sir!
Rail Community
