Can We Create a Vertical Curve on a Feature Line in Civil 3D?
kamalgaramja556
kamalgaramja556
Hello everyone,
I’m working on a grading project in Civil 3D and need to incorporate vertical curves along a feature line to ensure smooth elevation transitions. However, I’m unsure if this is possible directly or if there’s a workaround.
My Questions:
  1. Is there a native way to add parabolic or circular vertical curves to a feature line (similar to alignments or profiles)?
  2. If not, what are the best practices to approximate a vertical curve on a feature line?
  3. Are there any LISP routines, add-ons, or Civil 3D tricks to achieve this efficiently?
Desired Outcome:
A smooth surface derived from the feature line (with vertical curves) that dynamically updates in section drawings.
Joe-Bouza
The easiest way would be use and alignment and profile, where you can easily define the vertical curve, then extract the FL from alignment
Joe Bouza
kamalgaramja556
But I need it on Plan view. Matching the exact location. How to achieve ?
Joe-Bouza
That is exactly what that will do.
Instead of drawing a FL in plan, draw an alignment. Now profile and add your VC.
Now go to FL >> from alignment>> choose the profile > leave dynamic or turn off. You now have you VC in plan
Joe Bouza
