Can't select surfaces or feature line grips
I have a drawing that suddenly I can't select the surfaces for editing or select the feature line grips.  I can select the feature lines, and the grips are shown, but can't select them.  The surface is set to display points and triangles, but can't select the surface.  Both in-drawing and data shortcut surfaces are affected.  No locked layers, no locked surfaces.  Have recovered, audited, wblocked it out - no luck.  Only in this drawing - others behave normally.  Civil 3D 2016 SP3, W10Pro, I7-7700K, 32GB RAM.
Thanks, Charles
CivilFlow
Hi- Open a fresh session of C3D and type RECOVER in command line and find the problem dwg file. See if the RECOVER command will fix any errors. I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
I'm sure you've moved on, but I just had this happen today, so I'm sharing for future troubleshooters.  After a little investigation, the culprit was a skewed view.  Going to the view cube and resetting the view using the Top option corrected the problem.  Hope this helps.
