Civil 3D Forum
Can't import LandXML surface
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Keta_Engineering
107 Aufrufe, 2 Antworten
I've been asked to do some hydraulic modeling on a road reconstruction project that is out for bid.
The owner has provided the following existing ground surface (See Neck Lake Physical Data at the bottom of the list):
https://sam.gov/opp/6edfe277e3b14cc7abc142decd028f9c/view
The surface is a LandXML file created with microstation.  I can't get the surface to load.  My computer just sits and spins and nothing happens.  The XML file 198MB in size.
Is there any setting I can modify to make this happen or am I out of luck?
I'd appreciate any help or suggestions.
Happy New Year!
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Pointdump
als Antwort auf: Keta_Engineering
Hi Mark,
Try >>>This<<< from @Wojtek_Garczewski. Setting that I was able to import the surface.
Another option might be to import that surface into InfraWorks, then export to Civil 3D. (I don't have InfraWorks to test this.)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Nachricht 3 von 3
Keta_Engineering
als Antwort auf: Pointdump
Thank you Pointdump!
I already had the "Convert Survey Foot to International Foot" setting turned off in my LandXML settings, but the "Create Source Data in Drawing" was not.  I turned that off as suggested in the solution you linked and Presto!  It worked!
Thank you very much for the help!
Rail Community
