can't figure this layer out!
MKH-VB
MKH-VB
Greetings...I have been fighting this dwg for over an hour over 1 layer.  If someone has time to look at this for me, I would appreciate it so much.  If not, I certainly understand....heres the deal.  I have a sheet called "demo", and an xref called "x-base" (actual names are longer).  There is a layer within the "x-base" called cont-text which is my contour labels for my existing ground.  I cannot for the life of me get that layer to display in my demo dwg.  This is the only dwg in the set that this is happening in.  I can flip to mode space and turn on all layers and I see the labels, but not in PS.  All layer display settings are correct as far as I can tell.  I've attached a zip incase someone cares to look.
mkh
Jeff_M
The surface is on the C-TINN layer which is turned off in the Demo dwg. Turn it on and the labels appear after a Regen.
Jeff_M, also a frequent Swamper
brian.strandberg
Yep - was just about to post that.  I have an add on tool I use to debug those issues.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
MKH-VB
I knew it was simple!  I worked in all other dwgs.  I appreciate everyone checking into this for me.
MKH
mkh
tcorey
Probexreflayer? Is that your own? (And did you draw the alien in the icon? Scary.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
