Can`t export C3D objects to ACAD
Message 1 of 12
Can you have a go with exporting my C3D drawing to Acad drawing.
I`ve got only alingment with labels in my drawing and after exporting to cad there are stil C3D objects instead of lines and text.
Replies (11)
Message 2 of 12
M_c3d
Exports fine for me, see attached
Message 3 of 12
When I export the drawing a still get C3D objects.
Thanks for help.
Message 4 of 12
M_c3d
Try restarting civil 3d / restarting pc
Message 5 of 12
neilyj666
How are you exporting the data?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 12
M_c3d
That's a good question, I used the File > export to autocad > 2010 format
Message 7 of 12
jrauch
ExportC3DDrawing is the preferred function (over ExportToACAD). Not that it's always perfect, but it's much much better.
-John J. Rauch, P.E.
Message 8 of 12
I use Export Civil 3D Drawing from Output tab. I can`t still export labels from attached drawings...
I got only the axis without any labels.
Please anyone export these two drawings for me because I need them for tomorrow.
Message 9 of 12
jfengineering
I believe I was successful in exporting your files for you to ACAD 2010.
I have the same issue trying to export to ACAD with my own file.
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
Message 10 of 12
kubastan89
Post added by mistake.
Message 11 of 12
jfengineering
Unfortunately, I don't have any thoughts on why you can't get it to work.
Frustrating when that happens. I have a file that is doing the same thing,
I can't get it to export to ACAD. I finally saved it as R10 ACAD using the
.saveas command.
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
Message 12 of 12
I`ve exported C3D drawings before and it worked fine. I have no idea why it doesn`t work for me this time.
I`ve tried to save it as R14 ACAD but it doesn`t work for me either.
Well, let`s hope it will work with another drawings...
