Civil 3D Forum
Can't add elevation label to polylines
5 REPLIES 5
a176941
1893 Views, 5 Replies
Hello, I am still new to AutoCAD Civil 3D. I want to add elevation label to polylines but failed to do so. I already tried "Line and Curve" but I still couldnt do it. Any ideas how to label my polylines since I dont have any surface in my drawing. Thank you in advanced!
Labels (5)
5 REPLIES 5
lim.wendy
in reply to: a176941
Hello @a176941!
A warm welcome to the Civil 3D Community! Thank you for posting your question. 🙂
I've a quick look at your drawing, you have built the surface but the layer which the the surface is built in on Layer 0 and is turned off.
Look at the tip from this post on importing surface styles to stylize your surface.
Once you have the correct style applied to your surface, you can label the contours. Learn more here.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
using the wrong function, where you see line and curve, do down and select surface and then set your label type and and styles and you should be good to go. Sorry assumed that was a surface. You probably need to set the right settings for your label style assuming your pline is elevated.
jalnealFG
Created a quick video that explains how to get the types of labels you are looking for.
https://www.youtube.com/watch?v=i2fviJUG4QU
Grover_Puma
select poliline / add labels
LINE AND CURVE
CREATENEW
TEXT
GENERAL SEGMENT START Z / OK
IS THE SAME ELEVATION
if this helps to solve your problem, ACCEPT SOLUTION please, this will help others find immediate answers. Thank you
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
lim.wendy
in reply to: Grover_Puma
Hi @a176941
Thanks @Grover_Puma , @Anonymous , @jalnealFG for these great tips.
Do let us know if the suggestions help 🙂
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say “thank you!” and give recognition to whoever helped you. 🙂
Wendy Lim
Rails Summit
Rail Community
