Can`t add boundary to a surface
kubastan89
kubastan89
I try to add boundary to a surface but every time I add it I get error that adding boundary failed.
I was exploding boundary, recreating with BO command but it didn`t helped.
Could anyone have a look at attached drawing ?
Green line is a boundary I would like to add to a surface.
Regards.
Replies (8)
AllenJessup
I can't do much without the XML file that defines the Surface. But without it I had no problem adding the boundary in 2021.
Allen Jessup
CAD Manager - Designer
kubastan89
Hi @AllenJessup
I attach XML file.
I tried to add boundary in C3D 2021 but it doesn`t add it properly as in C3D 2020. Have a look at screencast below:
https://autode.sk/2FW6VZP
JRitner
I added the boundary to your surface w 0.001 mid-ordinate distance as you did, and it worked fine for me. One thing I did notice in your screencast -- you need to turn surface triangles on to view in object viewer.
Otherwise, all seems good.
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
AllenJessup
I can add the Polyline as a boundary. But it doesn't work right. The Surface reduces to one corner. If I draw a simplified polyline. I can add it to the Surface. I think you're trying to create too complex a boundary. With the Surface you've provided. I'd simply delete the the triangles you don't want.
Allen Jessup
kubastan89
Another screencast this time from C3D 2020:
https://autode.sk/3gwrUim
Could you share XML with added boundary with me ?
JRitner
XML with the finished surface & boundary. Hope it helps!
Joel Ritner
BIM/Systems Manager
kubastan89
Hi @JRitner
Did you manage to add a boundary or you edited surface by deleting the lines ?
JRitner
Just added the green polyline as a boundary.
Joel Ritner
BIM/Systems Manager
