Сообщество
Civil 3D Forum
отмена
Отображаются результаты для
Показать  только  | Вместо этого искать
Вы имели в виду:
Can someone do an UNDO test for me?
26 ОТВЕТ 26
РЕШЕНО
Ответить
Сообщение 1 из 27
Joe-Bouza
1012 просмотров, 26 ответов
I have experineced severe UNDO isues with 2013 & 2014 creating hundreds of grouped commands in the UNDO buffer making it impossible for me to deploy to the rest of the company. If I use the OOTB 2013 ot 2014 dwt file it does not happen but when I try to include our style it gets fouled up. It doesn't matter if I open saveas, insert explode, or import styles, the same UNDO problem comes into the picture.
So, if you currently DO NOT have an UNDO issue in either version I would appreciate it if you can see if my 2012 dwt causes the problem on your system. just rename to dwt
Joe Bouza
26 ОТВЕТ 26
Сообщение 21 из 27
AllenJessup
в ответ: Joe-Bouza
Well. The parcel would have been left behind when importing styles and settings from 2012. Neither QSelect nor List will pick up any blocks that are defined in the drawing if they're not inserted into that drawing. So you can have hundreds of blocks defined in a drawing and not be able to list any. Same goes for C3D styles. Thy don't show up unless you have something drawn or labeled with the style.
For a list of blocks defined in a drawing use -Insert > ?. It looks like you have 77 blocks defined in your template.
Allen
Allen Jessup
CAD Manager - Designer
Сообщение 22 из 27
Joe-Bouza
в ответ: AllenJessup
You misunderstood my question. You showed me a listing showing two hatch entities. were you saying they are in my file because I don't list them.
Joe Bouza
Сообщение 23 из 27
AllenJessup
в ответ: Joe-Bouza
No. Those weren't in your template. Those were ones I'd created to show you could have associative and nonassociative hatches. But I should have been doing Annotative. You can have annotative and nonanotative hatches also. But that doesn't show up in a list. You have to look at them in the properties Dialog to tell.
I'm not sure but I'd thing that any hatch created automatically by a Civil 3D routine would have to be associative. I don't think they would HAVE to be Annotative but that may be the way they are set to be created.
Allen
Allen Jessup
Сообщение 24 из 27
Joe-Bouza
Ok. I thought you were saying I had that situation. safe to say if I don't list any hatches that I don't have any annotative hatches, correct?
Joe Bouza
Сообщение 25 из 27
AllenJessup
в ответ: Joe-Bouza
No. What I was trying to say is that if there is an Annotative hatch associated with a block that is intrinsic to one of your styles. Then that block containing the Annotative hatch may trigger the Undo problem. I haven't had time to test that yet.
It has to be connected with one of your styles in some way. If I start from one of the OOTB templates or my template I don't get the problem. If you wanted to take the time. You could start a new blank drawing with no template and drag each style in one at a time and test for the problem after each one is brought in.
TIP: To reset the Undo list. Set Undo Control to None and then back to All. You'll lose the ability to undo past that point. But the Undo list will be clean.
Allen
Allen Jessup
Сообщение 26 из 27
Joe-Bouza
в ответ: Joe-Bouza
Confirmed Known Issuse I'll share with you all.
Thank you for choosing Autodesk Support. Our development team has identified an issue with pan/zoom where the setting to group these into one undo does not always work. I have also located several reports linked to the issue. The ticket number is 1468729 and is linked to this case.
There are several reports of various workarounds allowing the issue to go away. Please see if they help you too.
  • In AutoCAD's Options User Preference tab, be sure that the box for 'Combine zoom and pan commands' in the Undo/Redo section IS checked.
  • Run the ZOOM command, perform the Intellizooming with the mouse wheel, then exit the zoom command (press ESC). This will combine all of the undo entries into one ZOOM undo entry. Obviously this isn't as convenient as simply using the mouse wheel to zoom. But it does provide one workaround for the moment.
  • You can also try toggling on/off the UNDO command and also use the STATUS command to see how much data the UNDO command is “holding”. To do it you have to type UNDO in the command and choose the CONTROL or NONE options displayed in the prompt. The goal here is to limit the amount of data that the UNDO command is "holding" (information saved earlier in the editing session). To discard that data you can use the NONE option within the undo command.
I found other suggestions that your customers could try:
  • Check the value set to the UNDOCTL system variable:
    0 UNDO is turned off
    1 UNDO is turned on
    2 Only one command can be undone
    4 Auto is turned on
    8 A group is currently active
    16 Zoom and pan operations are grouped as a single action
    32 Layer property operations are grouped as a single action
Since this is a known issue I will link it with the case from the development team. This does not mean that the issue is solved or complete, it signifies that Support has now transitioned responsibility of defect to development directly.
Joe Bouza
Сообщение 27 из 27
AllenJessup
в ответ: Joe-Bouza
Some of that sounds familiar. I think if I would be using the Zoom command. I'd probably use other functions than the scroll wheel. Another tip. While it is no longer recognized, Zoom (V)max still works. This will zoom out the the maximum screen size possible without regenerating.
Allen
Allen Jessup
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
Новая тема
Rail Community
