Calculate Geological Layers Volumes
kubastan89
kubastan89
I have few tin surfaces created that correspond to geological layers.
I`d like to ask you how do you calculate each layer volume.
Red line shows Datum surface.
Color ones show tin surfaces that represent each geological layer.
Volume W1
Calculate volume between S1 and S2
Volume W2
Calculate volume between S2 and S3
Volume W3
Calculate volume between S3 and S4
Volume W4
Calculate volume between S4 and Datum surface
The problem is that Datum surface ones can end in W3, ones in W2 or in W5. It depends how geological layers will be created and how deep datum surface will be.
Any ideas about this ?
ecfernandez
Hi there, I think this is what you want. Right?
I uploaded the file so you can check how I did it. If you have any questions, post them. Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
kubastan89
Picture you added just shows materials, doesn`t show surfaces and conditions you assigned to each material.
Anyway I think this what you shows still doesn`t solve the problem when Datum layers ones ends in one layer and ones in another.
ecfernandez
That's why I attached the file I used. Check it and see if that solves your problem. I created a Layout profile that goes up through all the layers. Furthermore, I created five surfaces separated by 2m depth and computed the materials for every condition. By entering the sample line group properties you'll be able to see the computation.
Regards!
Camilo Fernández
LinkedIn
ecfernandez
I forgot to say. I even used the same names and colors of the image you posted for every surface (s1/green, s2/brown...). They are visible in the image I posted. Furthermore, I used the same name for the computation (w1, w2...). And as you said, according to the layout profile I used, the datum positions at a different depth/layer along the alignment.
Regards!
Camilo Fernández
LinkedIn
DRH_
hello, contributing a little to the subject I think this is what you need, I upload the file for you to analyze.
