Calculate distance between surfaces
izabella.russell
Community Visitor
Community Visitor
izabella.russell
Community Visitor
Community Visitor
I work as a Cad/BIM technician within the Geotechnical field. I have a ground-surface and a surface for the expected rock below. I would like to know the soil depth down to the rock-level by calculating/measuring the distance between the surfaces. Is this possible somehow?
cneely
You could create a spot elevation label that gives you the elevation of both surfaces. Use the Reference Text component for the 2nd surface.
AEC Collection 2022
WIN 10 PRO
Dell 3650, Intel i9-11900k @ 3.50GHz, 64 GB
NVIDIA QUADRO RTX 4000
http://www.cobbfendley.com
AllenJessup
I haven't done this. But... I think it would be possible to create a Label Style that would show the difference between two point using an Expression. Maybe something similar to this.
Allen Jessup
CAD Manager - Designer
cwr-pae
Create a volume surface, it will have "elevations" representing the difference between the 2 component surfaces at any point you choose. Just label spot elevations. If you need "comparative" labels (surface a elev -surface b elev = depth) use reference components to the other surfaces.
jmayo-EE
You may also find the MinimumDistanceBetweenSurfaces command useful. Also found in the Analyze tab (click the dropdown arrow) of the Modify Surface Ribbon tab.
John
John Mayo
