Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Calculate cut/fill areas on plan for volume surface
4 REPLIES 4
shashimanandhar1417
481 Views, 4 Replies
Hi everyone,
Just wondering if we can calculate or get cut/fill areas on plan like how much square meter of cut/fill areas on plan for given volume surface.
4 REPLIES 4
Hallo @shashimanandhar1417 ,
do you know this feature:
Here's a link to a workflow:
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Civi...
Kind regards,
Matt
jroot
in reply to: shashimanandhar1417
Assuming you have a volume surface made - do you have a surface style that shades the cut and fill?  If so you can turn on the boundaries and create a User Contour at elev zero (to create a boundary between cut/fill).  Then you can extract the boundaries & user contours as polylines and hatch the areas to get your square meters.
Buzz12345
in reply to: jroot
We have a volume legend table style that includes 2D area.
If you set up the analysis correctly then you'll get the cut area and the fill area.
Michael
AEC Collection - Civil3D 2023 & Infraworks 2023
www.foxsurvey.co.nz
Thank you. This method worked and very straight forward.
Rail Community
