CAD Coordinate system
my.yari90
my.yari90
I'm facing a bit of a conundrum and could really use your expertise to help me out.
Here's the deal: I've located a building with control points and Northing, Easting coordinates for an Aviation group to analyze the helipad location. So, I sent over the coordinates, but the building didn't show up in the right spot on their system. The problem is, I have no clue about the coordinate system the Aviation group is using. To fix this, I need to figure out what coordinate system my CAD/Survey data is based on. Any suggestions on how to accurately identify the coordinate system used in CAD/Survey data? Any tools or methods you can recommend?
tcorey
Are you a Civil 3D user?
Go to Settings tab of Toolspace, right click the drawing name and Edit Drawing Settings. Go to the Units and Zone tab. If a coordinate system has been assigned, it will be shown here. If none has been assigned, now you've got some sleuthing to do. Get a known latitude/longitude. Use _GeographicLocation command. This will place you on the world and will suggest coordinate systems you can assign to the drawing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Pointdump
Hi Mahsa yi,
More details please on how you got the control points. And can you post the Aviation Group's drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
