- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
That's "MESS" not "mesh."
Because someone else was working in the base drawing, I opened a copy to make an existing ground surface model.
Then what? So I decided to wblock the surface to its own BASE_EG.dwg, thinking I could then just insert it exploded into the base later.
So I tried it not realizing that the surface contained most all of the cogo points. I tried incrementing the duplicate point numbers, but that was an uncontrollable mess. So then I tried overwriting the duplicates but I got duplicates anyway, seriously, two point #893, etc. etc.
Now I think I'll have to xref attach the EG into the base, so that it travels along when the base is xreffed into the various plan sheets.
So, what's the best way to transfer a surface from one drawing to another? Is it possible without all the negative side effects?
John F. Uhden
