C3D label style how to make a border around text
lambertb
lambertb
Is there a way to make a nice border in a non dragged state when you have reference text? Currently, it seems to create 3 borders.
@BushW has edited your subject line for clarity: label border
C3D 2022 and 2024
BushW
Hello @lambertb
Yes, you can make a border for a non dragged state label.
Step 1: In your label style go to=>LAYOUT =>Component name: Reference textt XXX=>  Border = > Visiiblity=>FALSE.
This will turn off the border for a reference text component
Step 2: Go to Component name: xxx, then go adjust the Border=> Gap.
Adjust border Gap as needed.
I Hope this helps.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so and I'm here to help.
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
lambertb
I would like to make a single border around a label made of a couple components including reference text. As you can see in the picture, my label with multiple reference text doesn't work well but in a dragged state it looks good.
C3D 2022 and 2024
cwr-pae
Undragged you will get a border for each text component in the label. If you combine them into one component you get one border. For the reference text, copy and paste the contents of the reference component to the main component. This works for some label types. Otherwise, drag the label a tiny bit and turn off the leader and you get the appearance and dynamic location, but not rotation, of the label.
BushW
Hello @lambertb
I'm just checking in to see if you need more help with this. Did the reply of @cwr-pae provided work for you?
Please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
lambertb
One cannot make a single border around reference label components. Each component gets a border. The same holds true for background masking.
C3D 2022 and 2024
