Hi @JimJonesPELS.
I mean the feature line and the labels. In Grading-7 is there a surface for you? I opened here and the surface for this tutorial was there. I attached the XML file here with the surface, in case you can't find the folder with the XMLs, so you may import it into your file.
Grading-6 has an error with the surface importation, it seems. For me in the Grading-6 file, there are a feature line and the labels only. As I mentioned, it is easier to open the Grading-7 file, erase the edits and work from there.
About the xmls files: C:\Program Files\Autodesk\AutoCAD 2023\C3D\Help\Civil Tutorials. If the folder is empty or without the XMLs, it may be an installation issue.
There is an "EG_Surface_Grading.xml" that I believe is the file for this tutorial (you can check in the surface where it came from, properties -> definition -> there is a file address with the imported XML).
I agree with Rick, the Learning Courses are great. And if you need any help, there are (a lot) of good people around the forums, so do not hesitate!!
Best regards,
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution.
Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
