C3D Create profile geometry points abbreviation names-where is it?
sybold
sybold
how does civil name the points?
The alignment labels show the right names, BVP, BVC, EVC.
The generated points has the wrong name for the BVP?
where can i set it up?
@BushW has edited your subject line for clarity: profile geometry point creation point name?
Replies (13)
In toolspace, go to the settings tab and right click on the drawing.  Select drawing settings then go to the abbreviations tab.  All listed there
sybold
yes i know, for the labels it does use the correct one.
for the point descriptions it uses the wrong abbreviation.
I may found a bug here
BushW
Hello @sybold
@Anonymous is correct in his reply. In toolspace, go to => Settings tab and right click on the drawing.  Select drawing settings then go to =>Abbreviations tab => Alignment Geometry Point Entity Data
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so and I'm here to help.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
sybold
I am talking about the points from a vertical profile, not the alignment points!
The abbreviations are set Correctly, see attached.
With labels it works fine, when creating points it goes wrong.
The first point it creates should be BVP, as it is the start/begin of the vertical profile. Which is being labeled correctly by the label.
AllenJessup
I see what your problem is. You seem to have created points with the "Prompt for Descriptions" set to "Automatic - Object". The Cogo Point for the BVP is mislabeled BVC. The question is - Where does Civil 3D get that description from?
I haven't been able to find the answer yet but I'll keep looking as time permits. If you're on Maintenance or Subscription. You should start a Support Request with Autodesk. Someone there should be able to delve into that.
Allen Jessup
CAD Manager - Designer
sybold
correct yes.
It is logged at the subscription support, hope they find a solution or a fix.
BushW
Hello @sybold
Okay, now I understand where the issue is. Unfortunately, I will have to look into this matter and get back with by the end of the week.
Wendell
Wendell Bush
BushW
Hello @sybold
This Profile Geometry point label is associated with the Raw Description code. I suggest Disable Description Keys to <False> to see if that solves the labeling problem. I hope this helps.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit.
Best Regards,
Wendell
Wendell Bush
sybold
This doesn't resolve the labeling issue, default value was false.
AllenJessup
@sybold What is the Raw Description of the point and are there any Description Keys associated with it?
Allen Jessup
sybold
made a screencast.
point label is the raw description.
sybold
confirmed it is a defect by support
BushW
Hello @sybold
Yes, you are correct, and I have confirmed that this issue has been logged with the development team for investigation. Please do not hesitate to reply to this thread with any additional questions you may have regarding this matter or any message that you want me to share with development that we haven’t already discussed in this post.
You are also welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Best Regards,
Wendell
Wendell Bush
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
