C3D 2024 - Pressure Network DREF Not Matching Source
Cadguru42
Advisor Advisor
Cadguru42
Got a pressure network in a source file. Pipe goes into a reducer and looks fine in source file as shown below.
Here is the same pipe in the sheet file where the pressure network is DREF'd.
Why is this pipe crooked and not matching the source file? Sync doesn't fix it. Same parts lists, too.
C3D 2024-2026
Windows 11
32GB RAM
MSchille-1994
Did you try the Manage ribbon tab and then Manage Data Shortcuts?  If not, do that, and when the window opens, click on the Pressure Network in the left pane and it should highlight the same Pressure Network in the Right pane.  If not, select it in the right pane.  Either way, make sure they are both selected and then click the Link icon button in between the two panes and then click okay.
Did that fix it?
Attitude, not Aptitude, Determines Altitude
