C3D 2024 - Calculate surface areas
ochiguichonZT4YP
ochiguichonZT4YP
Looking for some suggestions to calculate surface areas from a 3D solid in Civil3D 2024.
Accepted solutions (3)
Joe-Bouza
Civil3d's / any civil software's TIN Algorithm does not support a surface created with two points sharing x,y and different z. No pure vertical face. you wall is pure vertical. Plus I think the solids need to be converted to faces
Joe Bouza
TerryDotson
As Joe mentioned, Civil3D is no help on this type of geometry.  However, you should be able to explode your 3dSolids and then do a CAD DATAEXTRACTION on the REGION objects to determine the area of each, doing further calculations in a spreadsheet.
ochiguichonZT4YP
@Joe-Bouza appreciate the input. @TerryDotson thank you for the tip, DATAEXTRACTION is very helpful.
